Sandsnow:
OK, I have to ask....how do you get 'natural light' after sundown??? Yes, we have houses with skylights in rooms, bathrooms, etc.
How could you have a bathroom without a light?? A attached garage without a light??
OK, real quick...
For new resi we do a "rough wire" inspection, "service" inspection, and "FINAL"
Upon "service" inspection & approval a cut-in card is faxed & mailed to the utility & the service is energized, usually in the name of the builder.
No power, no final; no HVAC CU no final, etc.
Comm is basically the same; with "ceiling".
I/we don't like TCO's for resi; most times whatever is 'amiss' can be addressed before the paperwork is processed. For a TCO, Elec; Plumb; Fire; Bldg & Engineering must all "sign off a TCO"; loose one & you're out of luck.
PS: Thank you gentlemen for the comments on the "list". Gee, I think it ay be tough to have the town buy a Inspector battery operated GFI tester. NJ does not enfoce the AFCI requirements.
[This message has been edited by HotLine1 (edited 08-02-2005).]
