Joe you would really appreciate Maui county. They require an extra inspection once the sheetrock is up with all the plates off so the inspectors can see the devices and makeup before the faceplates are installed. (nevermind that the wirenuts are blocking the view). Then you can call for final after you go back to put the plates on . Since I am only an electrician/elec contractor I realize my opinion won't sway you but I'm on Iwire's side of the fence on this.
