Banks have a way of dealing with the check problem. They are giving the merchant a scanner that either scans the whole check or just reads the MICR line. They process it right then and hand you the check back.
The first place I saw this was a brick yard. Now they are popping up all over. It is essentially what they do at the grocery store when they scan your check but they keep it.
You are not beating that one to the bank!
