Oops, almost forgot:
Roger;
that must be in the Bill Gates section.
LOL!!!
![[Linked Image]](https://www.electrical-contractor.net/ubb/biggrin.gif)
Glazing ver.3.1.020.330050a For Windows 9x / M.E. / N.T. / 2000 / XP
(Windows 3.0 / 3.1 / 3.11 not supported, due to 32 bit limitations - these versions may be referred to as "Single Pane Windows").
Microsoft strongly suggests the user installs the most current version of Direct-X in the Walls, prior to installation of Glazing for Windows, ver 3.1...
Direct-X 5.0 is oldest known version to be beta tested successfully with this version of Glazing for Windows, ver 3.1...
Macros may incorporated, and interfaced to other Walls via Active-X.
Prior to installation of Glazing for Windows, ver 3.1..., verify ample free space is available on the target drive Wall for the installation routines.
Before performing installation of Glazing for Windows, ver. 3.1..., remove any existing versions of Glazing for Windows, from the target drive Wall, using the application's uninstall routine.
Restart your Car, then proceed to install the newer version - Glazing for Windows, ver 3.1...
Do not install this newer version of Glazing for Windows, ver 3.1. over any existing versions, as this will result in instable conditions.
This would be the "Quick and Dirty" description from MS.
If anyone read the older MS text manuals (like "Introduction to Windows 3.1 for example), the above stuff will make you laugh!
Scott35
