I can add to the tally, Shattered nasal bone joint from a dropped pair of Footprint grips 18 years ago, Fractured skull from a dropped scaff clamp..I had a hard hat on!!
Broken Arm from tripping over some pipework a plumber hadn't fixed properly.
I also have a bad back and neck. I am not sure how much of the back/neck issue os job related though. As an apprentice I was in the 10th Battalion (Reserves), The Parachute Regiment and completed 178 jumps..they didn't all have happy endings
This is all exacebated by being 6ft 4" and 280 pounds (I need to lose about 20 pounds to get to ideal weight for body frame)
The moral is....be a short stocky bugger with thick skin, skull and back..you should retire in one piece then
![[Linked Image]](https://www.electrical-contractor.net/ubb/biggrin.gif)
