It’s been quite a while since I’ve done it, but now that I’m thinking about it, I believe the second method I mentioned concerning use of the 402K kit, only works if there is a cable box connected and powered up for the line being tested. As I recall, the 402K indicated the active line from the DC voltage of the cable box output.
