0 members (),
92
guests, and
18
robots. |
Key:
Admin,
Global Mod,
Mod
Posts: 873 Likes: 4
How will a transformer fail anyway? I don't know, but would assume that it would be the wire burning in half and/or shorting out due to over-amping. SMF
Faillures in dry transformers:
Insulation breakdown: Primary to secondary windings, this is one of the main reasons that the sec. winding needs to be earthed at a low voltage TX. to avoid getting a higher mains voltage on the sec. (safe) side.
Shorted turns: Depending on how well the windings touch each other eg. low resistance contact between turns means that the secondary becomes a single turn transformer and the winding will burn out very quickly and a lot of damage will be done to the remainder of the windings and a rewind or write off is necessary.
Winding open circuit: Could be at a tapping or shorted turn gone o.c.
Faillures in oil filled distribution transformers.
Same as for dry TX's and a few more below
In oil filled TX's there are acidity levels in old oil , ingress of moisture, deteriation of paper insulation to name a few.
In New Zealand we usually take oil samples twice a year from substation TX's to determine the condition of the oil and TX. Carbonlevels indicate some form of arcing at the windings or terminations. Acidity can cause leakage current to earth. lots of varnish can block radiator pipes and reduce circulation hence overheating etc.
I draw a line here now because I think the subject pertains more to dry TX's.
Merry X mas and a great 2006. Raymond
Entire Thread
Transformers: mind-boggling, mysterious beasts
Spark Master Flash
12/21/05 06:54 PM
Re: Transformers: mind-boggling, mysterious beasts
ghost307
12/21/05 07:06 PM
BobH
12/21/05 07:53 PM
jwhite
12/21/05 07:53 PM
Spark Master Flash
12/21/05 08:06 PM
jwhite
12/21/05 08:53 PM
Spark Master Flash
12/21/05 11:08 PM
Spock
12/21/05 11:41 PM
Spark Master Flash
12/22/05 12:12 AM
jwhite
12/22/05 12:26 AM
JoeTestingEngr
12/22/05 12:44 AM
jwhite
12/22/05 01:37 AM
Admin
12/22/05 03:52 AM
RODALCO
12/22/05 04:58 AM
Larry Fine
12/22/05 05:11 AM
Spark Master Flash
12/22/05 05:13 AM
Spark Master Flash
12/22/05 05:18 AM
Admin
12/22/05 05:50 AM
Spark Master Flash
12/22/05 10:49 AM
winnie
12/22/05 01:26 PM
WFO
12/22/05 02:30 PM
RODALCO
12/23/05 08:01 AM
Spark Master Flash
12/23/05 04:10 PM
SolarPowered
12/23/05 05:18 PM
WFO
12/23/05 07:11 PM
Spark Master Flash
12/23/05 07:44 PM
WFO
12/24/05 12:08 AM
Spark Master Flash
12/24/05 12:47 AM
winnie
12/24/05 02:29 AM
Scott35
12/24/05 02:40 AM
Scott35
12/24/05 02:48 AM
WFO
12/24/05 03:11 AM
Spark Master Flash
12/24/05 03:24 AM
JoeTestingEngr
12/24/05 04:06 AM
Larry Fine
12/24/05 04:20 AM
JoeTestingEngr
12/24/05 05:48 AM
Trumpy
12/24/05 10:11 AM
winnie
12/24/05 01:13 PM
Spark Master Flash
12/24/05 03:31 PM
iwire
12/24/05 03:48 PM
JoeTestingEngr
12/24/05 05:09 PM
JoeTestingEngr
12/24/05 05:10 PM
JoeTestingEngr
12/24/05 06:26 PM
Spark Master Flash
12/24/05 06:46 PM
JoeTestingEngr
12/24/05 07:31 PM
Dnkldorf
12/24/05 08:51 PM
Spark Master Flash
12/25/05 12:15 AM
Spark Master Flash
12/25/05 12:30 AM
Spark Master Flash
12/25/05 12:32 AM
WFO
12/25/05 12:35 AM
Spark Master Flash
12/25/05 03:09 AM
JoeTestingEngr
12/25/05 04:54 AM
