I think one of the easiest calls on whether to give somebody advice is if you are in his home and can see some of his DIY wiring.
If his previous attempts are properly installed, using the correct connectors, correct cable type and size, etc. then at least it appears that he is trying to do the right thing. On the other hand if I see cable sheaths stripped way back out of the boxes, wires twisted and taped, or any of the other tell-tale signs, then I'm more careful with my replies.
(Roger, I've seen extra outlets wired with flexible cord too, sometimes with a wire size roughly equivalent to your #18 and run off a 30A fuse!)
Have any of you practiced the art of replying to a question without actually answering it directly? (Politicians are masters of this, of course! [Linked Image])
Somebody wants to know what size wire to use for a such-and-such motor, for example, and it's clear from his previous questions or work that he's in over his head and shouldn't be attempting the job. An answer along the lines of "Well, it's quite complex and depends on several factors, like the size of the motor, the temperature in that attic...." might just make him realize how much he doesn't understand. You've replied to his question, without actually giving him the specific answer and without making him feel that he's being patronized.
I'd like to bring up another point regarding homeowners who ask questions not because they have done or intend to do the work themselves, but because they are concerned about an existing condition or about something that somebody else has installed. In this case, I think we should certainly give the person credit for seeing something that concerns him and for trying to seek proper advice.
Those who tout for business while having no idea what they are doing are a different matter entirely. I went to a nearby house some months ago and found that somebody had installed a new main panel and ripped out the main GFI. (The GFI was required in this case, as the ground was only to a local rod.) He had left the entire house with no ground-fault protection whatsoever.
My questions revealed that the person responsible had set himself up as a "professional electrician" some years earlier, but had since gone out of business. [Linked Image]
