Hello sandsnow, thanks for replying!
If you do not mind, I have a question to toss your way.
I haven't had the pleasure (agony) of enforcing, but I'm giving a class on Tuesday on just non-residential lighting.
Would your Plancheck Dept. accept the 2001 compliance forms (LTG), on a Planset submitted between October 5th and October 12th of this year?
I ask of this because there are two projects that I am designing, which will be going to Plancheck within those dates; and as mentioned in my previous post, I cannot find "Stand-Alone" 2005 version compliance forms.
I should elaborate a bit on this:I am looking for "Stand-Alone" compliance forms, instead of having to extract the ones included with the compliance manual.
I already have the 2001 version compliance forms in AutoCAD file format, which have been used as "Base Templates" on many projects in the past few years.
The AutoCAD file format versions are about the only useful ones for me, but with "some" (read: A WHOLE LOT OF!!!) effort, the .PDFs can be filled out, then converted into something I can import / attach to my AutoCAD page template(s), and plot with the complete "E" sheets planset.
The same externally referenced form(s) can also be printed on individual 8½"×11" pages, and compiled to a 3-ring binder (for Bldg. Dept. file archives).
Getting them out of the manual is a bit more work, but not impossible.
One other thing, when will your Dept. begin enforcing the items covered in the 2005 Non-Residential Compliance Manual?
Anyhow, feel free to contact me directly via E-mail if needed.
My address (phonetically) is:
setelectric
at pacbell
dot net
TIA!!!
Scott35
BTW, where can I sign up for your Non-Residential Lighting class, or other classes?
edited to add the above quandry regarding classes!
![[Linked Image]](https://www.electrical-contractor.net/ubb/smile.gif)
[This message has been edited by Scott35 (edited 10-01-2005).]
