0 members (), 1,141 guests, and 12 robots.
#78076 08/14/01 04:46 AM
sparky Offline OP
Can a typical RX connector be installed backwards? For example, the section with the two screws inside the panel or box....are there code and or listing violations that would arise?
Workgear for Electricians
#78077 08/14/01 06:09 AM
I have used them backwards inside WP boxes so I didnt have to drill an unnecessarily large hole in the siding on which I mounted the box. I will continue to do so.
#78078 08/14/01 07:26 AM
What...you don't use WP connectors with WP boxes?
-Virgil
5 Star Inspections
Member IAEI
#78079 08/14/01 07:38 AM
Redsy,
I like to use a short nipple with ducseal around it that seals when the box is screwed to the siding.
#78080 08/14/01 09:02 AM
Wait a minute here...
I don't have to use WP connectors (at $3.50 each)???
-Virgil
5 Star Inspections
Member IAEI
#78081 08/14/01 10:48 AM
When entering the rear of a wall mounted box, I place the box over the hole and caulk around the box.
#78082 08/14/01 06:01 PM
Tom Offline
I can't think of a violation that would cover this. I've done the same thing on occaision. I would say that you now have to make a one wire deduction from the number of conductors allowed in that box.
#78083 08/14/01 06:08 PM
Anonymous
Unregistered
I don't know what it should be a violation. Many boxes have clamps on the inside. Just deduct the appropriate amount from the box fill.
I do see how it might not be weatherproof.
#78084 08/14/01 06:12 PM
sparky Offline OP
370-16(b)(2)(No allowance shall be required for a clamping mechanism outside the box.)
until it's inside...
thanks Tom [Linked Image]
Redsy;
I do the same..
Virgil;
To your consolation, i do tell customers that there is no such thing as wheatherproof, despite listings, in the northeast.
Kinda like kid proof....
#78085 08/14/01 06:52 PM
Sparky,
As to your original Question, I would caution to watch for sharp edges at least.
