#78076 08/14/01 05:46 AM
sparky Offline OP
Can a typical RX connector be installed backwards? For example, the section with the two screws inside the panel or box....are there code and or listing violations that would arise?
#78077 08/14/01 07:09 AM
I have used them backwards inside WP boxes so I didnt have to drill an unnecessarily large hole in the siding on which I mounted the box. I will continue to do so.
#78078 08/14/01 08:26 AM
What...you don't use WP connectors with WP boxes?
-Virgil
5 Star Inspections
Member IAEI
#78079 08/14/01 08:38 AM
Redsy,
I like to use a short nipple with ducseal around it that seals when the box is screwed to the siding.
#78080 08/14/01 10:02 AM
Wait a minute here...
I don't have to use WP connectors (at $3.50 each)???
-Virgil
5 Star Inspections
Member IAEI
#78081 08/14/01 11:48 AM
When entering the rear of a wall mounted box, I place the box over the hole and caulk around the box.
#78082 08/14/01 07:01 PM
Tom Offline
I can't think of a violation that would cover this. I've done the same thing on occaision. I would say that you now have to make a one wire deduction from the number of conductors allowed in that box.
#78083 08/14/01 07:08 PM
Anonymous
Unregistered
I don't know what it should be a violation. Many boxes have clamps on the inside. Just deduct the appropriate amount from the box fill.
I do see how it might not be weatherproof.
#78084 08/14/01 07:12 PM
sparky Offline OP
370-16(b)(2)(No allowance shall be required for a clamping mechanism outside the box.)
until it's inside...
thanks Tom [Linked Image]
Redsy;
I do the same..
Virgil;
To your consolation, i do tell customers that there is no such thing as wheatherproof, despite listings, in the northeast.
Kinda like kid proof....
#78085 08/14/01 07:52 PM
Sparky,
As to your original Question, I would caution to watch for sharp edges at least.
