0 members (), 605 guests, and 12 robots.
sudsy4 Offline OP
Any suggestions on how to tap 4 panels (350MCM each) from 3 parrallel 600MCM feeders in a gutter?
Workgear for Electricians
'Polaris' type terminations; 600 to 350 range, 7 barrel, or 8 to be safe.
I am with John on this one. polaris connectors are the way to go, hope it is a BIG gutter!
Jimmy
sudsy4:
The 8 barrel Polaris is <11" long, with cable entry from either side. So, you need a troff at least 12".
They make a 'stacker' model also, but...it's not UL Listed.
Check out the link below.
http://www.polarisconnectors.com/pdfs/NSi/IPLD_series.pdf
