1 members (gfretwell), 163 guests, and 6 robots.
Hello,
I found these items in a box of fittings I purchased from the Murray Bridge area of South Australia. The area had a 250 VDC supply prior to the 240 VAC 50Hz being standard in the area.
The three pictures show the plug & socket. Unfortunately, the socket has a bit missing around the Earth pin. The markings on the back of the socket are:
MADE IN ENGLAND
VITREOUS
14522
5A 250V
The manufacturers' mark looks like a horseshoe magnet with wire around it with the letters GEC with this mark.
Darren Carroll
Alice Springs, NT, Australia
They're typical of British fittings of the 1940s/1950s era.
I mentioned elsewhere the possible switch interlock to prevent a switch being turned on until a plug was inserted, but there were definitely outlets which when mated with the correct plug did the opposite function, i.e. prevented you from removing a plug with the switch on. The recesses in the earth pin of that plug provided the function.
In the "old days" here, our Regs. specified that outlets on a D.C. supply had to be controlled by an integral or adjacent switch. There was no such requirement for A.C. outlets.
