166
14
C-H, It all makes sense now!
Paul, Yes, that's what I meant: a "serial operated cotactor" with push buttons. Is there no shorter word for this in English? In Dutch we call it a "Impulsschakelaar" - schakelaar meaning switch. We use them very often over here whenever we have 3 or more switches for 1 light e.g. long corridors or stairs. What do you use in England in such circumstances? 3 and 4 way switches? Even when you have 5 switches? Hre it would be seen more like a recepy for spaghetti. Another application is when the push buttons are next to swimming pools, then we use a 12V or 24V version. We can then use very thin wire fore the switches e.g. 0.6 mm2.
Posts: 1,498 Likes: 1
Pauluk, As a matter of interest, what are the Norwegian terms for line, neutral, etc.?
Here you go: Voltage = Spenning Current = Strøm Power = Effekt Phase = Fase Neutral = Null Earth = Jord Protective Earth = Beskyttelsesjord Conductor = Ledning Circuit = Kurs Grid = Nett System/installation = Anlegg Fuse = Sikring Fuse box = Sikringsskap Main fuse = Hovedsikring Main disconnect = Hovedbryter RCD = Jordfeilbryter Junction box = Koblingsboks Socket = Stikkontakt Light switch = Lysbryter Blackout = Strømutkobling Electrician = Elektriker Disclaimer: There could be errors in the above list.
C-H,
Very interesting! I could recognise nearly all the terms since they resemble very strongly to German and Dutch. So for RCD you say "earthfaildisconnect"? That's an interesting term. I didn"t understand the literal transalation of "Beskyttelses" and I didn't reconise the word "bryter"? For the rest everything seems like a dialect of German.
Well, my first lesson in Norwegian has been quite educational. (Any normal person would start by learning "Hello," "Goodbye," and "How are you?" ) What's the literal meaning of kobling? Current = Strøm Junction box = Koblingsboks Blackout = Strømutkobling
So Strømutkobling = Current-???? It looks a little like the way they string several words together to form a new term in German.
An addition: Old German term for RCD: FI or Fehlerstrominduktionsschutzschalter - literal translation: Fault current induction protection switch. Or a bit shorter Fehlerstrom-Schutzschalter - Fault current protection switch. Today electricians start calling it RCD (at least in Germany) but everybody will know what you mean by "FI". There are also a couple of weird homeowner terms that aren't really connected to the subject any more, like "Trennschutz" which means something like "protective disconnect" but isn't really a word.
Voltage: Spannung Current: Strom Power: Leistung Amperage: Stromstaerke
Phase: Phase (only different pronounciation, the A is like for example the second a in Hannah) and the e at the end is pronounced) Neutral: Nullleiter (Leiter is conductor) Ground: Erdung, Schutzleiter, PE
Circuit: Stromkreis, Kreis (if it is clear what kind of circuit is referred to) Grid: Netz System/Installation: System, Anlage/Installation
Fuse: Sicherung Fuse box: Sicherungskasten (old) or Verteiler Main fuse: Hauptsicherung Main disconnect: Hauptschalter Breaker: LS or Leitungsschutzschalter
Junction box: Verteilerdose Socket: Steckdose Switch: Schalter Light switch: Lichtschalter
Blackout: Stromausfall Electrician: Elektriker
Strip connector: Lusterklemme Wirenut: Drehverbinder Plug: Stecker Trailing socket: Kupplung or informal Steckdose
Neutral bus bar: N-Schiene Ground bus bar: PE-Schiene, Erdungsschiene DIN-rail: Hutschiene
Yes, Swedish, Danish and Norwegian are dialects of Plattdeutsch. So for RCD you say "earthfaildisconnect"?
Earth faultdisconnect I didn"t understand the literal transalation of "Beskyttelses"
Protection/protective. Compare to German "Schutz-" and Swedish "Skydds-" and I didn't reconise the word "bryter"?
Breaker. That's pretty similar, isn't it? Pauluk, we aren't normal are we? kobling = connection thus Strømutkobling = Current-dis-connection In the Nordic languages 'Strøm' is often used when you would have used 'power' in English.
I'll throw in the Swedish terms too, when I'm at it.
Voltage = Spänning Current = Ström Power = Effekt
Phase = Fas Neutral = Nolla Earth = Jord Protective Earth = Skyddsjord
Conductor = Ledare Circuit = Krets Grid = Nät System/installation = Anläggning
Fuse = Generally 'Säkring', specifically for mains power 'Propp' Fuse box = Proppskåp Main fuse = Huvudsäkring Main disconnect = Huvudbrytare RCD = Jordfelsbrytare
Junction box = Kopplingsbox Socket = 'Uttag' or collogially 'kontakt' Light switch = Strömbrytare or collogially 'lampknapp'
Blackout = Strömavbrott Electrician = Elektriker
An easy way to remember it: Kobling = Coupling Some English words are very similar to their corresponding words in Dutch....it's always interesting to read it and I can sometimes fanagle my way with it (reading it and tranlating it to corresponding words in English and German). I can't speak Dutch or understand it when I hear it on the radio, however.
It's a funny language, Dutch. As some of you guys, may know, I work with an Electrician from Holland, from time to time and although he has tried to explain to me how the Dutch language works, it seems so weird(sp?, can't even use English properly). I assume that Dutch is based on German?.
