For those who do not approve of the use of the clamp screw for EGC connections, I have 2 questions. Do you accept the use of the listed push-on green clamp for the termination of ECGs at a box? If yes, can you honestly say that you believe that the push-on clamp is a better grounding connection than the clamp screw?
Don
Don(resqcapt19)
