Brian,Welcome to ECN, its the mind that needs to be in the best shape, and yours sounds as if its OK. As you get older you get wiser and just because your not as fit as you used to be it does not prevent you from doing the job, you learn to think the job through more and cope that way. Good luck to you. Alan
