Sven:
I never said Italian plugs were easy to wire [Linked Image]
I find most schuko rewirable plugs that I've come across horrible to wire compared to UK ones. But then again UK rewirable plugs are huge.
Inside a normal Irish IS401 (BS1363) plug, fused at 13A.
[Linked Image from thediyworld.co.uk]
BS546 15A rewirable.. so much space you could park a small car inside!
[Linked Image from eskom.co.za]
(this gives you an idea of the size of these things ... look at the cable entering at the bottom in comparision to the plug size!)
[Linked Image from safety.org.sg]
Note this plug pre-dates sheathed pins and would be illegal thesedays.
[Linked Image from volexpowercords.com]
and a diagram of BS1363
[This message has been edited by djk (edited 10-31-2003).]
