As long as its a 3-way traveller OR the FEED to a switch, it may be white and does not have to be identified...
200.7(C)(1)&(2) state otherwise. If the conductor is used for other than a grounded conductor, it must be re-identified.
I was also told that if you connect a white identified as a hot" to a fixture or device thats also not legal!
That part is correct, 200.7(C)(2).
Don't believe everything you hear, unless there's a code to support the "rule."
