Just on the basis of the photo, what evidence do you have that says the red/white is a switch leg and not a outlet feed? I think you'd need to wait a bit on that one.
Cause it has "SSS" written on the wall next to a 3 gang....
I suspect you could find yourself in a battle over the use of dual copper-reenforced, vinyl-insulated strapping material.
Where does someone get some of that?
Mark Heller "Well - I oughta....." -Jackie Gleason
