Teaching, is not a repetive motion exercise... For the completely green, you need to throw some more dialog into the mix. i.e. "I want you to do (This), and I want you to do it this way.... And this.... is why I want you to do it this way...." Otherwise you get a robot that can't think for himself. I have had a few... And, all you have to do, is get used to describing everything. (One should also bear in mind that not everyone does things like you, if he works with other people, so if you know what those things are... describe those in detail.) Dare I say it, like you have said, you will learn more out of this.
