0 members (), 630 guests, and 12 robots.
#77850 07/18/01 06:57 PM
sparky Offline OP
Ok, I'm stumped. I admit it, maybe some of you guys can staighten me out.
I am bidding on a development. The utility is going to provide a meter bank at a cul-de-sac.
All homes will be supplied via a lateral. I am reading 230-70(a)
I am not used to seeing a residence without some external indication of the utility entry, so this seems strange..
any comments ??
Workgear for Electricians
#77851 07/18/01 07:22 PM
I think 230-70 (b) has the answer. Maybe? But like you that would baffle me for a while, not normal.
Whats worse is utilities are allowed to get away with murder against code. Not you and me!
#77852 07/18/01 08:00 PM
sparky Offline OP
so true...
It would seem that much of 230's intent is based on an emergency situation where location of a main(s) is needed.
This seems conflicting.
However 225-32 parrallels this, possibly i am just to fixated on a meter....
#77853 07/18/01 10:11 PM
Anonymous
Unregistered
Are mobile homes considered residences?
#77854 07/21/01 07:11 PM
Dspark, yeah I was thinking the same (mobile homes) when I read Sparky's post. Around here that's still rare that there is no indication of entrance. But I don't think it's critical.
#77855 07/21/01 09:06 PM
sparky Offline OP
Update;
a utility engineer is involved! so most likley i will assume a position of being told , not figuring myself, the end result.
this is a high end retirement cul-de-sac neighborhood, no mobile homes allowed!
I will post the engineer's spec's when i receive them, if only to make a comparative anaylisis to the NEC.
meanwhile i shall do my best Forrest Gump with the 'manual backhoe' in the ditch...
