0 members (), 117 guests, and 14 robots.
Page 3 of 3 1 2 3
As there is no guidance in the matter in the NEC, I look at it from a marketing point of view. Here in Northern Illinois grounds are down or to the right. From a marketing point of view...imagine your favorite client paying you $20,000 for their major rewire...they have a grand party and you've installed the grounds up because you think it matters. All the guests are looking at the new remodeling job & saying..."He installed the outlets upside down...GREAT JOB!"
Dave
If you have a grinding wheel, you can ground down the outlets. Of if you have an industrial shredder machine, you can ground them up... [Linked Image]
Having seen so many pictures of plugs plugged into receptacles with the ground pin hanging half way out of the slot, by the wieght on the plug, I would tend to think that ground down would be safer.
Just my $0.02 worth. [Linked Image]
I install them with the ground to the left. Neutral facing up... [Linked Image]
The German solution -- Ground up and down simultaneously! [Linked Image]
The 2005 NEC Handbook addresses this in 406.4(D). Receptacles shall be flush or protrude out--- then in the Green Print(which is an explanation of the code) it says The NEC doesn't specify the position (blades up or down)of a common vertically mounted 15 or 20 amp receptacle. it shows pictures throughout mounted both ways. i would recommend checking the job specs if there are any.
Page 3 of 3 1 2 3
