0 members (), 499 guests, and 11 robots.
wa2ise Offline OP
Wonder if they got the proper permits for that job. [Linked Image] And who will the inspector be? [Linked Image]
I wonder if we will get a whole new bunch of long distance DIY questions now. [Linked Image]
Roger
what intergalactic certification would be necessary to be AHJ out there? I'll bet Ryan J already has it [Linked Image] [Linked Image]
I want to see the ground rod.
And here I thought installing solar panels on someone's roof was a tall order.
And all this time I thought they just took a very long SO extension cord with them! [Linked Image]
That's Hilarious Reno!
Luke Clarke
Electrical Planner for TVA.
So, I wonder... Is this installation covered by the NEC, or is it perhaps covered by the codes of whatever jurisdiction it happens to be passing over at the time?
Who enforces the codes?
Is it easier to train an electrician to be an astronaut, or to train an astronaut to be an electrician?
How do you enforce the "on is up" rule for circuit breaker mounting when there is no "up"?
[This message has been edited by SolarPowered (edited 12-08-2006).]
Do you think they do ground pin up or down?
tkb Offline
Did the Intergalactic committee accept the 2005 or are they still on 2002????
