Electricians revenge
0 members (), 192 guests, and 14 robots.
#69025 08/25/06 04:41 PM
Checked my supplier, $960 fr.Calif. to Pa. (CH has a similar unit that starts #CMMB...)
[This message has been edited by derater (edited 08-25-2006).]
#69026 08/25/06 08:55 PM
I know in 50 years I'll be able to find breakers at a reasonable cost.
It might be a totally different ball game then. We may not even have circuit breakers as we know them today.
30 years ago I thought FPE Stabloks, and Zinscos were going to be around forever.
[This message has been edited by electure (edited 08-25-2006).]
#69027 08/26/06 12:04 AM
"30 years ago I thought FPE Stabloks, and Zinscos were going to be around forever"
From the number still out there they probably will be! [Linked Image]
#69028 08/26/06 12:05 AM
OK,
I've been delving more and more into the operations side of a friends contracting business. We have decided to work together, me utilizing my estimating and sales skills and knowledge of installation, and his skills in troubleshooting and commercial industrial installations.
I am trying to set myself further apart from the competitors... So, could you explain to me again, why the Cutler Hammer panels are better...
I understand the copper bus bar, is there a differnece in the breakers, anything else that I should know? And overall, on average how do the costs compare for say a BR to CH... I admit, I've always worked with the BR series... I know, bad me... [Linked Image] Just the contractors that I have worked with have never really looked into it... they use what they always used.
Can you guys give me more information, so that I can better upsell the customer? And, Les, Sorry, I know that you did explain some of this to me a while back, but I have forgotten.
Thanks,
Glen
#69029 08/26/06 12:54 PM
nov Offline
When a CH breaker trips the handle goes all the way to the off position, not in the middle like the BR and siemens. It just makes it easer for the homeowner to tell if it is tripped
#69030 08/26/06 01:03 PM
ehill Offline OP
You get more full-size breakers in a comparable amount of space.
#69031 08/27/06 06:02 PM
ehill Offline OP
CH breakers are also listed for two wires.
Eric
#69032 08/27/06 10:36 PM
For what it's worth, I've changed out my fair share of CH style resi panels, usually ater the main decided to self destruct. (see here for one of em). I think I also remember there was a metal bar that people would remove to get twin breakers inside the thing.
The supply house I typically use is a big Cutler Hammer supplier, but not for resi stuff... I'll ask how much just for the heck of it [Linked Image]
#69033 08/28/06 12:16 AM
I've always heard that QO has the best reputation.
Larry Fine
Fine Electric Co.
fineelectricco.com
#69034 08/28/06 12:25 AM
Thanks for the info guys.
I've also heard that CH makes a retrofit panel with splitter type connections in the corners, for wires that are too short from the old panel.
Has anyone ever tried them? Or know how they work?
