Electricians revenge
1 members (Scott35), 57 guests, and 11 robots.
#59773 12/14/05 09:21 PM
Oak floor joists at least 2" thick minimum,
Hand cranking the brace. The smaller the bit the easier it is to drill.
#59774 12/14/05 09:48 PM
Considering the torment that alot of the K & T I've come across has been through with 30A fuses, insulation, 200 watt light bulbs, etc. I think it's held up quite well all in all... The last K&T I dealt with was a house built in 1898... Sans the lack of grounding, the system was in fairly decent shape... I'd never even thought about all the holes being hand drilled before, EESH! [Linked Image] My hats off to those who walked in our steps before us.
#59775 12/15/05 09:32 AM
I have actually bored a hole by hand with a brace and bit before on occasions. In tight spots where's there's a risk of damaging something else should the drill slip, it can be a way of keeping greater control and reducing that risk.
#59776 12/15/05 11:12 AM
The last time I had to bore a hole with a brace'n'bit was back when I was a little ol' helper. We had to sink a wood pole in the middle of a lumber yard to raise a triplex that hung too low.
So, here I am on top of two stacks of rough-cut lumber, one on the other, then lifted to the max height of a large fork truck, and then I had to stand up a 28' wood ladder toi reach the top of the pole.
I used a length of NM as a makeshift harness so I could lean back and drill a 1/2" hole through the pole, maybe a foot thick at the top. That only took me about 20 minutes or so.
Then I inserted an eye-bolt, screwed a washer and nut on the back end, and use a come-along to pull the triplex up enough to attach it with the slip type of hanger, the kind with a steel wire loop.
Fun job!
Larry Fine
Fine Electric Co.
fineelectricco.com
