205
12
I have a carhart pouch I use...to carry my smokes, phone, tape measure and writing instruments (pen, pencil, sharpie, crayon, whatever). I rarely put a tool in the "tool pouch".
To carry the tools for day/job I use a bucket...a simple empty bucket w/no "liner" with a million pockets on it. It's simple, easy to see in and grab stuff out of...and I can also sit on it if the job calls for it (like putting in devices...bucket full of devices, wirenuts, pigtails, etc).
Two tools are in my pants pocket 90% of the time...my pliers and a 10-in-1 screwdriver (both Klien).
The "tool belt" is for my "stuff", the bucket is for tools.
~~ CELTIC ~~ ...-= NJ =-...
I was always more like Sierra electrician...40 pounds of stuff around my waste at all times. I don't even change light bulbs without my belt on.
Ryan Jackson, Salt Lake City
Thanx a lot guys, I start school at Glouster County Votec "NJ" in the fall. They made a new program for in the afternoon insted of morning. There still working on the program, but should be done in time for fall classes. I've been reading a lot in here. You guys / girls are great. I love the advise you all give. I hope to be here for awile. Thanx
Kermit
I have always worn a tool pouch since day 1 in the trade. I cannot stand to watch some of the younger guys running up and down the stairs or ladders for a driver or wirenuts etc. I have a pouch filled with misc parts for the day, phillips driver, small flat head, large flat head, torpedo level, linesmans, needle nose, key hole saw, tape measure, voltage testers, fluke volt pen tester, control screw driver, sharpie, pensil, side cutters and a flashlight. I think I got everything.
I know I will probably be regreting having so much weight on my hips later in life, but it sure saves alot of time going up and down the ladder.
I've developed a "two pouch" style.
My leather "Rough-in" pouch has the following shtuff...
Klein Journeyman "2000 series" steel cutting dikes* Klein 10-in-1 screwdriver Elecytrician's hammer Baby (8") stanley prybar 11" channel - locks Tubing cutter Klein (or Ideal) Conduit reaming screwdriver Klein conduit fitting pliers Swanson speed-square (6") with box k.o. spaces pre-marked, Lenox utility knife 30' Tape Measure China marker A couple of carpenter's pencils.
This gets put on the double nail pouch belt that holds 8 & 16p nails, assorted conduit straps, 1 1/4" 'drywall' type screws, couplings and connectors.
Obviously, this is used for the "grunt" work... throwing and dropping sticks & hanging boxes.
My "service pouch" is my nice nylon rig with the following:
Klein Journeyman Lineman's pliers w/ tape pulling jaws K J'man Needle nose pliers K J'man 2000 dikes K "wiring tool" (the narrow nose strippers w/crimpers & thread cutters) K 10-in-1 screwdriver K #2 & 1/4" slotted screwdrivers GB Insulated #2 phillips 8" Torpedo Level Greenlee GFCI/outlet tester Greenlee volt-tic Tubing cutter Channel-locks Vaco multi-nut driver (the telescoping sleeve one) Carpenter's pencils Rolls of tape
Ideal Vol-Con elite ("Wiggy" w/continuity & NCV test)
Clamp-on ammeter (Older... Amprobe/Sperry, perhaps?)
Like anything else, my tool pouches are in a state of continual development. As long as I keep getting different types of jobs, my choice of "at hand" tools will keep fluctuating too...
* The advantages of the "2000" series is that they will cut through steel nails, BX/Greenfield armor & can light hangers w/o developing nicks... so they'll cut regular Cu SOL until the cows come home. JMHO, but they're worth the extra $8-10 over the regular ones.
[This message has been edited by DougW (edited 05-24-2005).]
Just bought a new leather tool pouch (Ideal brand) that is flat on the bottom, has a handle and strap and has a lot more room than the hip carring kind. And your tools don't fall out all the time. Works great!
I used a tool pouch for 15 years and started to have back problems. My doctor told me my spine was twisted because of wearing the tool belt every day. What I had done wrong was to have all my tools on one side and things like wire nuts tape and small parts on the other side. This made the tool belt heavier on one side which twisted my spine
I bought a tool bag, made by Rigid, a few months ago. It's great. Large enough for just about everything, including 18 volt drill, hammer, hacksaw, brick chisels and pry bar. The only bad thing is that it weighs a ton but it is worth the trade off to save trips to the van when I need a tool.
