347
15
I was at the home show in Bawstin today and there were a couple of landscape lighting company's pushing there products, low voltage landscape lighting.
He said that he is not required to have a electricians licence to do this work of installing these systems.
I argued that he did.
Who was right?
shortcircuit
It depends on the local jurisdiction. Our jurisdiction allows non-licensed installers to install the low voltage lighting (still requires a permit for inspection), if it is hard wired for the line side of the transformer, they have to hire a licensed electrical contractor for that portion of the installation.
Pierre Belarge
We had a heated debate with one of those manufacturers on this subject in this forum (I think) many months back. Seems that because it is low voltage manufacturers think that no codes apply and there also is no safety issue.
Although the NEC sections are minimal, 300.5 gives the minimum cover requirement for buried landscape lighting cable and 411.1 gives the equirements for lighting systems 30 volts or less, these are code requirements.
To answer your question, I think it would be up to the AHJ's in each area as to how they want to deal with this issue. I think I vaguely remember some area requiring landscapers to take a short course and pass a test on these areas which would then allow them to install the lighting.
-Hal
Reading through the Mass Gen laws I don't see a clear answer. I might tend to agree with him on the assumption that he looked into it before he started this part of his business. I really don't see the need for a license to do this.
Here in NJ I believe that anyone can install low voltage lights if the transformer plugs in. A permit is required if the install is new.
Shortcircuit knowing you are a fellow MA resident I agree with you. GENERAL LAWS OF MASSACHUSETTS PART I. ADMINISTRATION OF THE GOVERNMENT
TITLE XX. PUBLIC SAFETY AND GOOD ORDER
CHAPTER 141. SUPERVISION OF ELECTRICIANS
Chapter 141: Section 1A Licensure requirement; exceptions
Section 1A. No person, firm or corporation shall enter into, engage in, or work at the business or occupation of installing wires, conduits, apparatus, devices, fixtures, or other appliances for carrying or using electricity for light, heat, power, fire warning or security system purposes, unless such person, firm or corporation shall be licensed by the state examiners of electricians in accordance with this chapter and, with respect to security systems, unless such person, firm or corporation shall also be licensed by the commissioner of public safety in accordance with the provisions of sections fifty-seven to sixty-one, inclusive, of chapter one hundred and forty-seven.
This chapter shall not apply to: a person not engaged in the business described in this section who employs or contracts for the services of a person, firm or corporation engaged in such business; or to an apprentice employed by a person, firm or corporation licensed in accordance with this chapter; or to an agent, employee or assistant of a person, firm or corporation licensed in accordance with this chapter who does not engage in or perform the actual work described in this section. http://www.mass.gov/legis/laws/mgl/141-1a.htm Thats what I believe the law says, what really happens is another story. Bob
After Bob's post and reading alittle more it looks like a license in needed. Does not seem necessary to me.
Shortcircuit & iwire here in Ma it is legal for a homeowner to pull a permit to install these lights. So the landscaper has the HO pull a permit and he rides off into the sunset with a big wad of cash in his pocket. Just another thing about this state I do not care for.
Al
Hi Al I agree that can be one way, I think most times they just do not pull a permit in the first place. Of course that never happens... ![[Linked Image]](https://www.electrical-contractor.net/ubb/wink.gif) Bob
I can see the occasional landscaper installing some lights and getting away with it,(like going 60 in a 55mph zone)but these guys are engaged in the business of installing these lighting systems for "HIRE" and they are not licensed to do so ![[Linked Image]](https://www.electrical-contractor.net/ubb/mad.gif) You see the key word here in Massachusetts is for "HIRE"(section 3L)...this is what allows homeowners to do there own work. shortcircuit
