1 members (Yumper), 227 guests, and 16 robots.
#45293 11/22/04 06:34 PM
detubbs Offline OP
"I have the National Electrical Estimator, & it is fairly easy to use, & resonably priced...it allows you to change any of the prices, & has the ability to enter mark-up for different catagories.
Comes with a CD & a paperback book.
I've found their labor estimates (for time required) to be very close, & their material prices seem to be a little higher than I find here in Kentucky."
Where did you get this program? what was the cost? does it have "everything" as far as materials or do ya hafta fudge everynow and then? i saw that in accubid (3000$+), when you select "conduit" it takes into account for couplers/screw/hangers/etc. for every stick. i've been using a free sample of "BidforBuild" to try and get a rough labor idea.
Scott
#45294 11/22/04 09:46 PM
http://www.craftsman book.com/products/info/ne5.htm
#45295 11/22/04 10:00 PM
detubbs Offline OP
thanks IAN! have you experianced this program? do you know how big of jobs you can estimate with it?
Scott
#45296 11/23/04 09:01 PM
I have used it a few times but for fairly small jobs so I really couldn't say for sure what it's limitations are. I would think however that it can be used for large jobs as the program basically allows you to create a list of material to be used for a job and assigns a cost for the material and associates a quantity of time to each unit of material. For example, say you are going to install 120 feet of EMT, it would assign the cost of the EMT at say $6/unit (1 unit = 10 ft length) and say 1 hour labor per unit for installation. You can set the hourly rate so say you have it set for $50/hr. In this example the estimate would be (12units*$6/unit=$96 for material) + (12units* 1hr/unit*$50/hr=$600 for labor)= Total Estimate for material + Labor = $696. I've made up the numbers here but you hopefully this gives you the general idea of how it works.
#45297 11/23/04 09:09 PM
Oh, I think I left a dash "-" out of the link above. Try this instead
http://www.craftsman-book.com/products/info/ne5.htm
