0 members (), 965 guests, and 9 robots.
#39928 07/06/04 07:39 PM
Has anybody looked at these yet? http://www.passandseymour.com/whatsnew/plugtail.html . I wonder what the long term reliablity will be, and how well that thing in the back stays in.
Theres always enough room in the junction box.You just need a bigger hammer
#39929 07/06/04 08:06 PM
e57 Offline
Our usual rocker crew will have a hay day with those! Guarranteed to have every wire, and that plug tore up, bag and plug full of mud.
#39930 07/06/04 08:23 PM
Did everyone notice that in the picture the outlet is installed gound pin up? [Linked Image]
#39931 07/06/04 08:43 PM
I wonder if they'll eventually come in "audio grade"... [Linked Image] [Linked Image] [Linked Image] [Linked Image] [Linked Image]
Sorry folks, I just couldn't resist!
Actually, it does look pretty slick.
No wire bias here- I'm standing on neutral ground.
#39932 07/06/04 09:59 PM
Sir Arcs — You could always buy a Dewar of liquid nitrogen and make your own. www.google.com/search?hl=en&ie=UTF-8&q=audio+grade+cryogenic+receptacle
#39933 07/06/04 10:51 PM
So do you think they use 12 or 14 awg wire on the pigtail, and how would that affect the install if put on a 20 amp circ?
#39934 07/06/04 11:28 PM
"Did everyone notice that in the picture the outlet is installed gound pin up?"
Yes, I noticed that it was upside down, too! It even has writing on it that's right reading when it's rightside up, and they still got it wrong. [Linked Image]
#39935 07/07/04 05:25 AM
3
www.clipsal.com/quickconnect/quickconnect.cfm
shows a different method of connecting to outlets using insulation displacement connectors
#39936 07/07/04 06:23 AM
F
The cut sheet says the PlugTail conductors are #12 THHN copper conductor, 6" leads, stripped, solid or stranded and rated as permanent part of the device.
#39937 07/07/04 04:47 PM
It looks a little odd at first, but thinking about it further it should be all right so long as the actually connectors are tight.
It looks as though they might be a slight variation on the 1/4-inch spade terminals which are common in automotive applications. The latter stand up to high-ish currents at low voltages, with lots of movement and vibration.
