Electricians revenge
1 members (Scott35), 57 guests, and 11 robots.
#36156 03/30/04 06:47 PM
Bob: You've told me that before, and I find it interesting about your amendments. I find it particularly interesting that electrons move slower in Massachussettes than any other state in the nation [Linked Image], such as evident by the 310.15(?) or 310.16(?) amendment for conductor ampacity.
Ryan Jackson,
Salt Lake City
#36157 03/30/04 07:41 PM
Ryan I was curious about the change in derating here in MA and Don R hooked me up. [Linked Image]
The table we use was the table from the NEC and you can still see it in Annex B Table B.310.11
The difference is we still consider load diversity and the NEC no longer does.
The remarking issue is more about "if you do not know what your doing keep your fingers out of electric boxes" [Linked Image]
#36158 03/30/04 08:12 PM
As a matter of preference, I almost always bring power in at the switch. I generally use a 3 conductor cable between the switch and the ceiling box, to allow for future wiring of a fan/light with independent control. For a standard switch installation, I just cap off the red wire at both ends.
#36159 03/31/04 04:52 AM
I understand that for commercial work in the UK, one can obtain twin plus ground cable with two hot coloured wires specially for loop-ins.
Yes, "Twin & Earth" with two red wires instead of red/black has been available for quite a while in the smaller 1 and 1.5mm sizes used for lighting circuits. It doesn't seem to be that widely used, though.
