0 members (), 368 guests, and 26 robots.
#32801 01/03/04 11:20 PM
Once again, " Someone needs to add some more chlorine to the gene pool", comes to mind.
#32802 01/05/04 04:48 PM
And this guy at least asked for advise. Imagine the sheer number of people that just go ahead a do stuff like that and not give it a second thought. Scary! [Linked Image]
#32803 01/05/04 09:32 PM
F
I don't have to imagine. I run into that kind of stuff all the time. The trouble is when you try to explain to someone that it needs to be "repaired to code". It's worked fine all these years is usually what I hear.
Along the line of "adding chlorine to the gene pool" has anybody heard of the Darwin Awards?
[This message has been edited by fla sparkey (edited 01-05-2004).]
#32804 01/06/04 06:49 AM
Grounding is certainly an area which seems to be greatly misunderstood, both in the intented purpose and in the way in which it must be done to ensure safety.
#32805 01/07/04 09:46 AM
I went to that website and started reading some of the questions. Will keep the fire department on stand-by.
