Electricians revenge
1 members (Scott35), 29 guests, and 10 robots.
#28266 08/15/03 11:49 AM
Redsy Offline OP
Several times, people have expressed concern about occasionally (especially in an emergency)opening a feeder circuit breaker or an equipment disconnect switch under load.
As long as it is properly rated, and it is not an isolation switch, I don't see why there should be any problem.
Your thoughts, please?
I had a similar discussion on an air conditioning web site.
Disconnects for a/c and motor equipment are horsepower rated and sized accordingly to allow for disconnect operation under load.
[This message has been edited by wolfdog (edited 08-15-2003).]
And wouldn't an HP-rated disconnect also be designed to break the load of a stalled motor?
