0 members (), 338 guests, and 11 robots.
#27513 07/19/03 07:41 AM
sparky Offline OP
Mama does want to see 4 exhaust fan ducts on her new house, just one 'big one' well hidden.
Is there a mini-HVAC, or similar unit i can install in the cellar of a residence?
the idea is to pipe all down to it.....
Steve (aka clueless) sparky
#27514 07/19/03 08:55 AM
I think Nutone makes an inline ductable(is that a word [Linked Image] ) fan that one can hide in an attic(only place I've heard of them being used). Not sure if they are big enough for a whole house though as I've seen them on back to back bathrooms.
#27515 07/19/03 02:43 PM
Sparky, I recently used a Broan remote fan that had 4 4" inlets and 1 6" outlet mounted in the crawlspace. I piped all 4 bathrooms into it. It seems to work well.
I think the model # is mp280,don't remember the cfms.
Russell
#27516 07/19/03 07:36 PM
sparky Offline OP
ok Russ,
how did you switch it?
#27517 07/19/03 09:38 PM
Sparky, I used an allen bradley contactor with a 24v coil, used 24v transformer,ran 16ga. thermostat wire to a single pole switch in each bath.
Thats the only way my feeble mind could figure out.
Russell
#27518 07/19/03 09:54 PM
sparky Offline OP
that doesn't sound so bad Russ, i might have to give it a go.....thanx!
#27519 07/20/03 09:09 AM
Doesn't Nutone make a lot of equipment for central vacuum cleaner systems? I seem to recall seeing a catalog of such under that name.
#27520 07/20/03 11:39 AM
They sure do Paul.
They will sell you a complete vac system,inlets,piping,fittings, the whole 9 yards.
Russell
#27521 07/21/03 10:54 AM
Fantech also makes a remote exhaust fan.
http://www.fantech.net
#27522 07/21/03 12:29 PM
Sparky:
See if this helps any.
http://www.toolbase.org/tertiaryT.asp?TrackID=&CategoryID=1435&DocumentID=2088
http://www.ductworks.net/
[This message has been edited by ThinkGood (edited 07-21-2003).]
