0 members (), 191 guests, and 12 robots.
Isaac Offline OP
weird issue with a 240volt light
I have three lights not working. I wired a new barn. I was thinking maybe all three lights don't work on the same switch line.
I have 240 volts at the light boxes. I took the lights home, I wired the lights at home at 240volts, they work. The other lights in the barn work.
I don't understand how i have 240 volts at the light box, but light won't turn on?
Any suggestions?
What kind of light? Some discharge type lamps do not like the cold.
Isaac Offline OP
Led lamps
I don't know a lot about LEDs in the cold but it might still be your issue if this barn is unheated.
Are these bulbs that screw into a fixture? If so, maybe the bulbs aren't making contact with the base spring of the socket you used.
Is there 240V at the fixture?
