AE-Gifts, Affordable Everyday
0 members (), 160 guests, and 41 robots.
#219396 06/04/18 05:51 PM
twh Offline OP
I have a friend who owns a house in Montana. His fridge is on an AFCI breaker that trips every time they have a power failure. In Canada, we don't AFCI fridge plugs. Do you not have an exception for fridges?
twh #219397 06/04/18 07:41 PM
Short answer no.
twh #219398 06/04/18 09:41 PM
twh Offline OP
Are you allowed to install an AFCI in a box beside the panel. I wonder if it's the make of the breaker that is the problem.
twh #219399 06/05/18 03:47 PM
There are rules about how to do it but generally yes you can use a device type AFCI in the first outlet on a branch circuit if it is less than 50' away (wire length). The easiest way to comply is to use a piece of MC cable between the box and the panel. If it is a straight shot you could even use a piece of EMT or a close nipple for a side by side install. It just has to be in metal.
Before I did all of that I would try it on a GFCI only circuit. If that trips look inward toward the fridge. It is not uncommon for old fridges with bad compressors to trip GFCIs.
twh Offline OP
Good idea!
Trumpy
Trumpy
SI,New Zealand
560,989 Are you busy
434,625 Re: Forum
403,418 Need opinion
