Electricians revenge
1 members (Scott35), 50 guests, and 11 robots.
#20092 01/08/03 09:50 PM
derater Offline OP
Just did a small 'in-laws addition and likely went a bit heavy on the feeds.Is there a simple sq. ft./amp.Btw,per the builders layout.thanks.
#20093 01/08/03 10:06 PM
My formula was, I guess still is even though I don’t do much residential anymore as follows:
Square footage of room times 8 for new construction or a tight house.
Square footage of room times 10 for an older / drafty house
It seemed to work fine I would fudge it depending on the room as well maybe a little more for the bathroom a little less for the bedroom.
#20094 01/08/03 10:07 PM
Oh yeah forgot one important thing that’s the wattage!!
#20095 01/08/03 10:22 PM
That's a good method, also you can go by the cubic foot, which makes for ceiling heights, some ceilings are pretty high. 2 watts per cu.ft.
#20096 01/09/03 12:24 AM
In years past we installed 10 watts per sq ft. With new energy requirements (attic insullation, double pane windows, etc, allow us to install only 3 watts per sq ft. I've never known an inspector to check the wattage of installed heaters. When in doubt I install on the high side of 3W/sq.ft. I believe the inspectors allow a maximum of 3,ooo watts installed on a 20 amp 240 volt circuit.Here in Seattle it does not get below 30 degrees too often. bob
