ShoutChat Box
Danish type K Sockets
by dsk - 02/23/20 02:42 AM
15 amp outlets removed due to cell phones
by BigB - 02/20/20 07:23 PM
Square D "All-In-One" Panelboard
by gfretwell - 02/18/20 07:38 PM
2020 code
by shortcircuit - 02/11/20 04:30 PM
Facebook follies, bad wiring
FPE in Germany pt.2
1 registered members (Scott35), 50 guests, and 8 spiders.
flexible conduit repair #195391 07/29/10 10:25 PM
jay8 Offline OP
Anyone know of an approved product that can be used to repair broken/separated flexible metallic conduit? I have a 4" flex with 500mcm feeders to switchgear with the flex broken. So I am hoping I can repair in place without shutdown, remove,replace flex, repull, reterminate, etc etc.
Re: flexible conduit repair [Re: jay8] #195394 07/29/10 10:35 PM
HotLine1 Offline
Jay:
There is no product that I know of for what you described.
Looks like an R&R job
Re: flexible conduit repair [Re: HotLine1] #195398 07/29/10 10:46 PM
gfretwell Offline
The first question would be how was it separated in the first place. You may have a physical damage problem that precludes FMC.
I have seen people weave this stuff back together but I still would not try it hot. This was not uncommon under computer room floors. I even had a picture in the IAEI magazine of that. Joe T may still have it on his web site in the violations area.
Re: flexible conduit repair [Re: gfretwell] #195405 07/30/10 06:06 PM
Tesla Offline
Such damage, presumably within the Electrical Room, is very disturbing.
I rather suspect that the flex was buckled during the original installation.
Alternately, the custodian/owner has been stacking 'stuff' on top of the flex until failure.
We've all seen it: the E Room becomes the closet to jamb everything under the sun for the custodian.
I see an R&R in your future.
Tesla
Re: flexible conduit repair [Re: Tesla] #195409 07/31/10 12:41 AM
noderaser Offline
Duct Tape :P
Re: flexible conduit repair [Re: Tesla] #195459 08/03/10 09:34 PM
jay8 Offline OP
It was likely due to installation damage since its location makes it unlikely to be hit. It was a little tedious but I was able to wind it back together since it was fairly close to the connector, which saved quite a bit of grief. I knew there were approved kits to repair in use underground conduit, so I was fishing for something similar for flex. thanks for the feedback - i will save the duct tape repair idea for another time.
2020 National Electrical Code
Code (NEC)
2017 Master Electrician Exam Preparation Combos
2017 NEC Electrician
Exam Prep Combos:
Master / Journeyman
HappyElectrician
HappyElectrician
Penn USA
Show All Member Profiles
dsk 6
djk 5
Admin 3
cgw 2
263,593 Are you busy
198,663 Re: Forum
187,560 Need opinion
Powered by UBB.threads™ PHP Forum Software 7.7.3
