0 members (), 1,034 guests, and 15 robots.
#18464 12/10/02 02:26 AM
Trumpy Offline OP
What sizes of Electrical Conduit are common in the US?.
For PVC and other types.
What is the largest size available?.
Your Help please-
#18465 12/10/02 10:16 AM
It varies by application, but 3/4" and 1" are the most common for branch circuits in many commercial and industrial situations. For feeders and the like, it can vary from 1.25" all the way up to 6", depending on the size of the wires, of course.
The available sizes of conduit are 1/2", 3/4", 1", 1.25", 1.5", 2", 2.5", 3", 3.5", 4", 5" and 6".
PVC is available in sizes up to 6". Metal conduit, such as EMT and Ridgid, is available in these sizes as well, although I am not sure if it is available in 5" and 6".
[This message has been edited by CTwireman (edited 12-10-2002).]
Peter
#18466 12/10/02 02:14 PM
CT, I suprised that you still use the trade size instead of the "Metric Designator" used in the 2002 code book.
16 = 1/2", 21 = 3/4", 27 = 1", 35 = 1 1/4", 41 = 1 1/2", 53 = 2", 63 = 2 1/2", 78 = 3", 103 = 4", 129 = 5", and 155 for 6".
"Hey Jimmy, as your 1st job as an electrician's helper, go to the truck and get 30.48 meters of #16 conduit!"
Is anybody really using meteric measurements?
Rick
#18467 12/10/02 04:29 PM
Hey Rick, you're right. I haven't purchased the '02 yet. My state is still on the '99, so that explains why I used the "old" designations.
<drives to supply house to get new code book>
I forgot the Code is metric now. My bad.
Peter
PS. I haven't seen anyone using metric measurements. I don't even see metric tape measures for sale anywhere.
I guess wire is next. "Hey, go get a 151 meter spool of 2.O mm THHN." Yuck!!
Peter
#18468 12/10/02 04:40 PM
I see both metric and English/US Customary units in the '02 NEC.
As the conversions are rounded rather than exact (e.g. 900mm is not exactly 3 ft.) I assumed that it was intended that the metric units be employed in those countries which are traditionally use metric measurements(this being the first "international" NEC) and that the English units are for the U.S.A.
Peter,
Hard to find a tape measure in this country which doesn't include millimeters. I had to order one from Arizona last time I needed a replacement!
Take a look here .
[This message has been edited by pauluk (edited 12-10-2002).]
#18469 12/10/02 04:44 PM
Paul, thanks for the correction (once again), I didn't mean to imply the code was all metric, I meant Metric/English, heavy emphasis on metric, although I suspect most here will continue to use the English units primarily. Please correct me if I am wrong.
Peter
Peter
#18470 12/10/02 04:45 PM
Sorry Peter -- I was editing my message as you posted. Should work now!
#18471 12/10/02 08:52 PM
EMT and IMC are only available up to 4" -eh ehm- #103 trade size. PVC, and GRC are available up to 6" (#155)
[This message has been edited by Nick (edited 12-10-2002).]
#18472 12/10/02 09:02 PM
I did have to run 8" once. It was for pulling broadcast cables, complete with ends, in for special broadcasts from a remote truck to a stage. After the shot it all gets pulled out and everyone goes away. We had to use 8" irrigation type pipe with custom made sweeps. 8" trade size is not made in listed PVC conduit.
#18473 12/11/02 12:25 AM
Trumpy Offline OP
Rick,
Those are strange Metric sizes.
Our sizes over in NZ here are(OD)
16,20,25,32,40,50 and 60mm.
It comes in Grey Medium Duty, Orange for where Chemical Resistance is required and
Black Heavy duty for where rugged mechanical
protection is required.
We also have flexible corrugated PVC conduit,
in these sizes.
