Electricians revenge
1 members (Scott35), 196 guests, and 11 robots.
e57 #165640 07/02/07 01:37 AM
As long as they are different it really doesn't make any difference.
That's the key -- Minimal coupling by use of different twist rates.
I just looked at three differnt rolls of 5E and amount of twist on all in decending order most to least - Orange, blue, green, brown. HUH?????
Here's the cable I was examining. I think it's clear enough to see the order of most-to-least twist is blue, green, orange, brown:
K
Check the links on this site for more info than you ever wanted to know on this subject.
http://www.leviton.com/OA_HTML/ibeCCtpSctDspRte.jsp?section=13753&minisite=10028
e57 #165955 07/08/07 04:12 PM
The amount of twist in any one pair of wires in a CAT5 cable is not operationally significant. In fact they differ between manufacturers. The difference in twist frequency is there to prevent the pairs from nesting as they run through the cable thus REDUCING XT. If the orange or green pair doesn't seem twisted enough up to the termination, twist it yourself. You won't hurt the integrity of the cable.
U
I've ben using "B" terminations since I started (7 years ago). Seemed to be more debate on which to use back then.
The "beyond Cat6" stuff they pulled into a local Telco office had a plastic divider in the cable to separate the pairs. I guess that prevents nesting even better.
