0 members (), 1,912 guests, and 10 robots.
#163135 05/01/07 09:19 PM
K
kinetic Offline OP
For one reason or another Section 230 has always given me trouble. I have never fully understood it and am looking for some clarification. I am wiring a detached garage and upgrading an existing 200A service to a 400A all-in-one. One main 200A breaker will supply the main house with the other 200A main supplying a 200A 40/42 space 3R subpanel at the detached garage. The problem I am having is that 42 spaces is not enough. With all the circuits in the garage I am still under on the load calcs but over on the breaker spaces. Can I feed an additional subpanel from my 200A subpanel?
Workgear for Electricians
kinetic #163140 05/01/07 11:15 PM
Sure
kinetic #163154 05/02/07 06:33 PM
shocked That sounds like one busy garage! Is there going to be a workshop in there?
I speak, of course, from Maine, where many folks live in trailers, situated next to palatial garages. grin
Retired_Helper #163158 05/02/07 08:44 PM
Must be one really nice garage!!
Yes, you can add a sub-panel....or two if needed.
kinetic #163238 05/04/07 05:37 PM
as others have said, yes you can.
can you tell use why or how a garage is using all 42 breakers spaces?
?? confusedJust curious??
Niko #163243 05/04/07 06:54 PM
I want that garage...
...Might have to implode half the section for it though.
Ian A.
Theelectrikid #163250 05/04/07 07:55 PM
I am using a pretty big panel in my garage (SqD 20/40) and it is full with a couple tandems and a sub on for the spa.
If you start out with one of those 4 high/2 wide breakers to feed the house the slots start going away fast. I still agree 42 is a lot.
kinetic #163297 05/05/07 08:09 PM
Can he use 310.15 (B)(6) for his garage feeder ampacity? grin
ShockMe77 #163305 05/05/07 10:48 PM
310.15 (B)(6) can be used if you are going from the garage to the house but not the other way.
gfretwell #163741 05/16/07 12:21 AM
K
kinetic Offline OP
It is one killer garage. He is a "Need for Speed" guy and moving part of his shop to his house. Everything seems to be small 220V and it really ate up my panel spaces. We put anything and everything you could think of this place. I am envious to say the least.
