Electricians revenge
0 members (), 205 guests, and 12 robots.
C-H Offline
Alan,
I of course can't answer for all EU countries, but for the Scandinavian countries it is law or standard. It seems laws are replaced by standards only. In theory, you could use any standard as long as you can show that it is as good as or better than the national standard. But try convincing a court that an alternative standard is better than the national standard...
C-H, Take your point, but tell me if I am wrong, if something is not set in tablets of stone is that not the reason why we tend to see so much more electrical work that's below the standard rather than above the standard. Is electrical installation work a weeekend D.I.Y. pastime in the Scandinavian countries as it is in the U.K?
C-H Offline
Yes, but unlike the UK a license is required for electrical work. We are talking 1000+ hours of work as an appy and an exam to get it. Happily ignored by many of course, but it means rough traders can have their license revoked.
djk Offline
Electrical systems in Europe vary quite a bit from place to place. There are various legacy colour codes, various legacy earthing/grounding systems in place.
While modern installations are broadly quite similar right across the EU thanks to cenelec harmonisation, if you open up an older installation it can look like something from another planet.
Unlike most other professions there is a real need for electricians to know about the system they're dealing with.
I think the simplest sollution would be to introduce a short-course system in each country. So for example, if an Austrian electrician wanted to work in Ireland we could presume that he/she knows the basics. A course could be offered that teaches about the local code here in Ireland and highlights the quirks one might expect to find in the system. Once that course is completed he/she would be qualified to work in Ireland.
I don't think it's fair to expect a qualified electrician to completely retrain for no reason nor do I think it's safe to let people work on unfamilar systems without learning about them first.
These older systems are going to be around for quite a while and it's not really practical/safe to just pretend that they don't exsist.
BTW: I am all in favour of harmonising the EU on one single, sensible electrical system. I think a hybrid system taking the best ideas from all of the various national codes could be great.
[This message has been edited by djk (edited 05-23-2004).]
DJK, I agree with your every point, do you think any of them will come to fruition in our lifetime. Certainly not mine any way I am 61,I look back at some of the changes that have taken place in my time as a contractor. Its been slow, the industry seems to resent change no matter what the reason. Remember the proposal in the seventies to have a harmonised socket outlet. Did it die or was it killed?
Good point on a "short course." If the only training for a particular country is a full course of study starting with the basics, electricians from other countries are soon going to get fed-up with having to go over Ohm's Law and similar "kids' stuff."
Aland,
Do you remember the proposal back in the mid-1970s for a standardized plug with three flat pins? They were arranged parallel, the center earth pin slightly offset, and rated 16A. The design would have allowed two such outlets in the space of a British single-gang plate. There were even photos in magazines, so I assume that prototypes were made.
I don't remember ever hearing any more about them. No doubt the IEE firmly rejected the idea because it would have meant abandoning fused plugs and ring circuits. (Regulars will already know that I'm not exactly a supporter of rings! [Linked Image]).
Pauluk, yes I do remember the proposed socket, in fact I am sutch a sado I still have a copy of a booklet published by M.K. detailing the virtues of the Worldwide plug and socket system. Apparently the first discussions took place as long ago as 1966 at an IEEC meeting held in of all places Tel Aviv. It took ten years of swanning around the world to different countries before any sort of a firm proposal could be agreed on. The agreement was to vote on three proposals
1) The CEE system based on the Europlug concept.
2) A Flat-pin proposal with sleeved pins.
3) A Flat-pin proposal with a recessed socket.
I think that the commitee members are probably talking about it if the truth is known. One of the old cherries thats good for a delegate meeting in some distant resort for many a year. I am an old synic arnt I. Sorry
djk Offline
With the addition of more EU members and with CENELECs expansion eastwards it's very unlikely that anything other than CEE 7/7 will be adopted as standard in Europe. The reality is that apart from a handfull of countries either the German or French (or compatable) outlet is used and the CEE 7/7 plug fits both.
While there's a technical argument, due to ring circuits to keep BS1363, I really can't see the logic of keeping the other non-fused radial-based sockets in use.
Of the other systems 2 are polarised when used with a grounded plug, i.e. Denmark and Switzerland. They could be replaced with the French system giving them compatability with CEE 7/7.
and the Italian system is easily replacable with Schuko.
Personally, I think that the Danish and Swiss systems are potentially leathal as they're fully capable of accepting a grounded CEE 7/7 (or old French/German) plug without completing the earth/ground connection.
The Italian system's 10A outlets won't accept a 16A schuko plug and the 16A outlets have wider pin spacing so also won't accept a grounded CEE 7/7 plug.
Interestingly, before CEE 7/7 the French and German systems were safely incompatable.
The old french plugs are fully round and won't fit into a Schuko outlet and the German plugs won't fit into a French outlet as the protruding pin prevents them from being inserted.
Interestingly, if you bypass the shuttering on a UK/Irish BS1363 socket, which is very easy to do on most of them (just push something into the earth recepticle), you can easily insert a 2-pin European plug.
I've even seen a few schuko plugs jammed in! The pins are almost too fat to fit in, but if you give them a good push they fit!
More modern MK outlets use 2 and 3 way shuttering which makes that impossible as all 3 pins must be inserted in the correct sequence.
However, I've had to cut schuko plugs off IT equipment, coffee machines, and even a commercial display fridge as they were being used in BS1363 sockets! i.e. without any form of earthing!!
This tends to happen, particularly, where the applience is rarely plugged out e.g. a coffee machine or a piece of office equipment and thanks to the switches on most Irish sockets you can even isolate the applience without removing the plug.
If it's just a 2-pin Europlug or a contour plug it's not too bad, particularly in Ireland, where 16/20A radials are normal. However where it's grounded schuko it's potentially leathal.
In the UK it's potentially a serious fire hazard as you could be plugging your applience directly into a circuit only protected by a 32A breaker or even worse, a rewirable fuse!
I still think that BS1363 could easily be replaced by a socket that's compatable with CEE 7/7 and fused. All you'd have to do is include a simple cartridge fuse carrier on the socket that accepts either a 13 or 16A BS1362 fuse.
I can't understand IEE's polarisation argument. British appliences all comply with various european standards and should be quite safe working on a non-polarised supply. However, we could adopt the French outlet and keep some degree of polarisation on class 1 appliences.
The UK already allows various unpolarised connectors.
i.e. "figure of 8" connectors so commonly used to connect small class 2 appliences like radios, videos, satellite boxes, audio equipment etc.
We also now allow the use of a permanently fitted plug adaptor which can only be removed with a tool. This pretty much encases a 2-pin Europlug inside a slightly oversized BS1363 plug. However, there is no way of knowing what the polarity of that plug is as the Europlug could have been inserted either way.
Anyway I guess there's no point in ranting on [Linked Image] The technical committees tend to be a BIT nationalistic in their approach and I doubt that will ever change!
As I recall from the pictures (I was only about 10 at the time!) this is the option they chose.
Like the quote C-H posted a while ago, about a committee meeting in the "typical French department of Guadeloupe...." [Linked Image]
At 38, I think I've become an old cynic as well. [Linked Image]
