1 members (Scott35), 410 guests, and 22 robots.
Page 5 of 5 1 2 3 4 5
Ragnar, try breaking off the pins with a wire cutter and then drilling out the remains?
Then probably you can use the recess in the plastic to mount a standard cassette-recorder AC inlet. Of course you'll also need to figure out a switch in order for it to go between AC operation or batteries.
If you get a figure-8 inlet from a trashed boombox, the switch is usually incorporated in the connector. It's hard to find those switched inlets in the parts after-market.
If I'm not seriously mistaken, some genius tried to fasten the inlet by melting the plastic with a soldering iron during a repair attempt. S/he also tried to solder around in the 220V AC part, don't ask me why. The inlet is bigger than a figure-8 inlet, so it'll definitely take some ingenuity.
That#s exactly what I plan on doing. I got loads of bottom-of-the-line junk cassette recorders and I'm going to use one for spares. Not going to bother fixed it's shot amplifier!
Ranger,
What type of Cartridge does this Player use?
You might have a hard time locating the correct Stylus for the Cartridge, and may need to just get a new Cartridge - with a few extra Styli for future replacement. (hoping you do not need to go this route!).
I had a legacy Turntable - with a legacy Ceramic Cartridge (missing the Stylus - of course!), and could not locate any compatible replacement Styli anywhere!
Ended up replacing the Cartridge with a "P" Mount type (and a few extra Styli, too!).
Cost was around $25.00 (USD) for everything, but this was in 1993!
BTW, not sure how the original Cartridge's Amplified Output sounded, but the new one sounded excellent!
And I am a "Die-Hard Magnetic Cartridge" person!
Scott35
Oops... got that one wrong. The entire cartridge is missing! I've just got loose wires with a strange 2-pin plug. I'll try to take a picture of that and post it.
There's a mail-order company in Indiana which you might find useful. They carry all sorts of replacement stylii and cartridges, including many older types:
http://www.garage-a-records.com
I've also used a place here in England in the past called the Expert Stylus Company.
They don't have a website, but can supply all sorts of obscure and obsolete stylii:
Expert Stylus Company,
P.O. Box 3
Ashtead
Surrey, KT21 2QD
Tel.+44 1372 276604
Fax:+44 1372 276147
Email: w.hodgson@btclick.com
Ragnar, what happened with that Eumig radio you menioned a while back on this thread?
It's still sitting around in storage and waiting for someone to take care of it. Probably the caps should be replaced, but it works as is.
