0 members (), 41 guests, and 10 robots.
#140086 01/23/04 09:42 AM
Trumpy Offline OP
Just had a reply from Paul over in another area.
And the last part really caught my eye.
The water bye-laws banned them some years ago due to the possibility of back-siphonage, but there must be many still in use.
That's a really good point Paul, even after anything is deemed unsafe or not good, things like these can hang around in places for years after the fact!.
There are thousands of Transformers here that are full of Askerels and PCB's, but they still work, so who cares?.
We are to a certain extent still getting rid of Lead pipes in houses here and also although it was banned years ago, lead flashing still seals God knows how many houses, up until a few years back some of these houses used to drink the run-off from the roofs!.
It's all one big mess, ban it and watch it disappear instantly, eh?. [Linked Image]
#140087 01/24/04 07:55 AM
There are still plenty of old houses here with a lead water service pipe, and you'll certainly still see plenty of lead used as flashing on roofs and gutters (I have some on mine!).
What I find annoying though is where scare tactics are used to try to make somebody upgrade their house to meet current regs. over some trivial little thing. For example, the fact that the earth wires were not normally sleeved in outlet boxes in older installations whereas sleeving is a requirement now, hardly makes that old system dangerous, does it?
#140088 01/24/04 08:29 AM
Trumpy Offline OP
Good Lord Paul!
For example, the fact that the earth wires were not normally sleeved in outlet boxes in older installations.
The typical English trying to do things on the cheap!. [Linked Image]
I'm not laughing though Paul, we had the very same cable over here and it is still in a lot of 60's-70's houses here. only thing is it's starting to leak Green plasticiser slime, these days and for God sakes, don't get it on your skin or in a open cut!, if you do wash it off as quick as you can!. [Linked Image]
