My 14" monitor decided to go out with an impressive display of flashes across the screen and a burning smell over the weekend.
![[Linked Image]](https://www.electrical-contractor.net/ubb/frown.gif)
I spent a little time inside it, but soon realized that enough components had been smoked to make it not worth spending any more time or money on. It also happened to be the only SVGA monitor I had here at the time (ain't that typical?), so I dashed out and picked up a cheap 17" monitor at the local "big box" store, the only place open around here on a Sunday.
The larger CRT certainly makes the itty-bitty text on some web-pages that much easy to read, and with an increased screen setting saves some horizontal scrolling on a lot of pages.
The only thing I don't like about it is having to go through a whole load of silly on-screen menus to adjust brightness, contrast, height, etc. You know the drill: Press the menu button, use the arrow keys to select the option you want from a load of cryptic symbols, hold the OK button until the option turns green while chanting the appropriate incantation........
![[Linked Image]](https://www.electrical-contractor.net/ubb/biggrin.gif)
I prefer the "old-fashioned" approach of physical controls for such adjustments.
[This message has been edited by pauluk (edited 07-28-2003).]
