546
21
Do any of you use temporary help from agencies when you run short of employees and need "electricians"? It doesn't always work too well for us. ...S
I use to work for a company that did a lot of industral work in Cranbury, NJ and they used temps that would come by the dozen. The owner would get 10 to 20 guys send all back home but 1 or 2 that were even somewhat educated. And all that would be in the first few hours.
The whole process would just repeat daily.
LMAO I hope you didnt pay for a "journeyman"! -Randy
Well, as long as the conduit and other conductors doesn't exceed the maximum fill ratio... Still, that's a mighty short run
I've worked for some temp. to hire places before and usually they look for people who have *some* experience before they just send them out to the job. No wonder you guys weed them out so fast.
I knew better than that before I ever started in this trade. That is horrible, but what do you expect from people who probably only get $6/hr or so.
I would be find it extremely difficult not to invoice the temp agency for three times what they tried to charge for mop-up after their “electricians”.
Look on the bright side... at least those set-screw connectors are UL listed!
We have gotten a couple of guys that were pretty good from agencies, even hired some full time. When I saw this though, I just couldn't resist. In his defense, these connectors were in tight.
And once the cover is on, nobody will be able to tamper with those set-screws, right? You'd have thought that the row of connectors fitted along the back of this raceway might have given a slight clue as to the correct procedure.
Scott, I know what you mean there!. We employed a temp "Electrician" at work here a couple of years back and the guy was an expert in installing PVC conduit, as crooked as I've never seen since. Not only did he bend it crookedly, he saddled it that way too. It was depressing to see such a good job turn bad!.
