460
8
Posts: 3,672 Likes: 5
Administrator Member
This was in a kitchen remodel at a church. The plumber installed a water heater under the sink and instead of having an electrician put an outlet where it was needed cut a hole in the sink lip and ran his cord through it. There is no grommet or other protection where the cord goes through the metal.
Alan Nadon ![[Linked Image]](https://www.electrical-contractor.net/Forum/Images/ElectricSink.jpg)
Man oh man... that is one classy install.
I suppose it could have been worse. He could have tried to run it down inside the overflow! ![[Linked Image]](https://www.electrical-contractor.net/ubb/eek.gif)
I suppose it could have been worse. He could have tried to run it down inside the overflow! ~pauluk ------------------------------ Such a sink doesn't have an overflow, but at least there's a GFCI. ![[Linked Image]](https://www.electrical-contractor.net/ubb/tongue.gif)
...and it's only because of the intellect of the electrician (and maybe the NEC)that the GFCI is there to begin with (although locating a receptacle of any kind directly behind a sink doesn't seem like a great idea).
Unfortunately, it seems that a lot of church installations are done by well meaning but seriously misguided people - usually on a volunteer basis.
Posts: 2,520 Likes: 2
Must be another US thing - in Europe I've yet had to see a sink without an overflow.
I guess the receptacle was there before the sink...
Posts: 5,485 Likes: 5
If I had to guess, Texas, I'd guess that this kitchen was re-modeled. I suspect that the original sink was a single basin (to one side of the receptacle), and that the cord goes to a garbage disposall under the sink. (How the disposall is switched is anyone's guess!)
Maybe.
As far as the handwriting on the picture goes the cord supplies a water heater.
Texas, you're right! I must have been having a "stupid" attack! OOPS!
Church remodel? Ah Ha!!!! There must have neen a reason so I think that I know the answer. Either it's a means for one to meet his maker or a way for one to have a "born again" experience.
