0 members (), 977 guests, and 9 robots.
#110698 06/07/06 07:46 PM
This was in a kitchen remodel at a church.
The plumber installed a water heater under the sink and instead of having an electrician put an outlet where it was needed cut a hole in the sink lip and ran his cord through it. There is no grommet or other protection where the cord goes through the metal.
Alan Nadon
#110699 06/08/06 12:12 AM
Man oh man... that is one classy install.
#110700 06/08/06 05:53 AM
I suppose it could have been worse. He could have tried to run it down inside the overflow! [Linked Image]
#110701 06/08/06 09:33 AM
I suppose it could have been worse. He could have tried to run it down inside the overflow! ~pauluk
Such a sink doesn't have an overflow, but at least there's a GFCI. [Linked Image]
#110702 06/08/06 10:00 AM
...and it's only because of the intellect of the electrician (and maybe the NEC)that the GFCI is there to begin with (although locating a receptacle of any kind directly behind a sink doesn't seem like a great idea).
Unfortunately, it seems that a lot of church installations are done by well meaning but seriously misguided people - usually on a volunteer basis.
#110703 06/08/06 11:03 AM
Must be another US thing - in Europe I've yet had to see a sink without an overflow.
I guess the receptacle was there before the sink...
#110704 06/09/06 07:53 PM
If I had to guess, Texas, I'd guess that this kitchen was re-modeled. I suspect that the original sink was a single basin (to one side of the receptacle), and that the cord goes to a garbage disposall under the sink.
(How the disposall is switched is anyone's guess!)
#110705 06/10/06 09:24 AM
Maybe.
As far as the handwriting on the picture goes the cord supplies a water heater.
#110706 06/10/06 11:40 AM
Texas, you're right! I must have been having a "stupid" attack! OOPS!
#110707 06/10/06 02:24 PM
Church remodel?
Ah Ha!!!! There must have neen a reason so I think that I know the answer.
Either it's a means for one to meet his maker or a way for one to have a "born again" experience.
