Electricians revenge
0 members (), 205 guests, and 12 robots.
#107218 11/10/04 01:16 PM
Admin Online Content OP
(submitted by electricman2)
#107219 11/10/04 03:36 PM
You can tell when you're getting jaded.
My first thought was "well, at least they made an attempt at grounding..." [Linked Image]
#107220 11/10/04 10:54 PM
Man... I have been seaching for invisible extension rings and can never find them at the supply house. I wonder if that's a raco or thepitt?
#107221 11/11/04 04:50 PM
This is located in an Antique Emporium. The owner was replacing a damaged ceiling panel and discovered it, then called me. The flex feeds the fan motor of a hot water unit heater which is no longer used. I disconnected it and installed a blank cover. The bare wire is looped around a screw in the cover and then to the box cover mounting screw. I admit, this is a first for me. [Linked Image]
#107222 11/11/04 06:11 PM
Arseegee,
LOL [Linked Image]
Roger
#107223 11/13/04 11:04 AM
I think the same company makes them as makes that Invisidorf that George Corron keeps not seeing everywhere
[This message has been edited by electure (edited 11-13-2004).]
#107224 11/13/04 05:06 PM
Check your invoices, they should show a charge for them. Problem is that when you do an inventory, they are tough to count as you can't see them... [Linked Image]
