0 members (), 454 guests, and 22 robots.
Would You Want This Panelboard In Your Home?
[This message has been edited by Joe Tedesco (edited 05-07-2004).]
Why is it that most painters are clueless to the fact that we really don't wan't paint inside our panels???? & that there IS a reason for that!?!! (resistance).. This one looks like its working on its 2nd coat! [Linked Image]
At least it has a separate ground bar! [Linked Image]
-Randy
I'm pretty firm with customers about not coming for the final until after the painting is done. I also carry painters masking tape on the truck to prevent this.
One of my least favorite things is having the customer tell me he's rolling the paint and when I come back, he hired someone who sprayed and all the wires are white.
Dave
The obvious problem with the paint aside, It bothers me to see a small panel such as this stuffed with all those tandem breakers. It seems like a method of cost cutting, instead of installing a nice full-sized panel with full size breakers, and at least a little room for growth.
Joe: I hope they didn't paint the buss connections as well! [Linked Image]
Someone also suggested that this equipment may have been under water at one time. I think NEMA has a recommended standard or guide for the subject of floods and electrical equipment?
Besides being painted, and probably overcrowded (tandems) it sure looks like a 3 wire panel, as I see no ground conductor, nor ground block!
That leads me to believe it is either a 'sub' or a "no-main", but there's more than 6 switches. Red Tag time!
It is a sub panel the equipment ground bar is in the left side so no issue there. It also is probably an 8/16 type panel. (Eight full size breakers or eight tandem breakers) so no problem there. I guess the main issue here is the paint.
The panel looks like a I-T-E panel, most C/B's are Bryant/ Westinghouse,I always cut a cover out of the box the panel came in but that will not stop some bozo from pulling it out, lazy painters w/ their airless and drywall hangers with a router get my blood boiling.
Looks like the painter thought that the box was just a junction for neutrals..... [Linked Image]
I hate going into a house and seeing electrical equipment painted over. The worst is when someone has deliberately painted all the switches and outlets to match the wall. [Linked Image]
I thought that one is not supposed to reidentify the phase conductors white [Linked Image] [Linked Image]
I have seen this many times. If that was my work, I would have it replaced at the painters expense.
I also see red and black conductors under the same phase - I wonder if that is from the same cable?
Pierre
Pierre Belarge
