Sorry to bring this up again but I think that something has to be mentioned here. A Megohm meter does not work by magic and it is a simple bit of test gear to use. Like a few test instruments, it works with Ohms Law in mind, having to find relevant results is a no-brainer. You should be able to work out in your head what the relative condition of the installation is by the test results. There are fewer simpler test instruments, apart from a Bell Set.
